View Full Version : c5501
CrapAimer
10-07-2015, 04:42 PM
Hi All
have a problem with a C5501 It has a double image, have changed the fuser belt and roller also the transfer cleaning unit, it is always in the same position, any help appreciated
George
habik
10-07-2015, 09:51 PM
When you print A3 multiples does it move on the page with same distance or over to next page.
Or
Is it spot on the same place every print?
Also what are the measurements between the images?
CrapAimer
10-08-2015, 12:50 PM
Hi
On A3 the first half of the copy is coming out on the second bit if that makes sense. if I was copying 2 a4's on to A3 the first a4's image would be on the second bit.
George
Mick01
10-12-2015, 11:33 PM
Hi,
All colours or just one??
You haven't by chance left the orange screws inside the drum? this wil cause your issue.
If you stop the paper before it enters the fusing unit does the double image issue appear?
Hope this helps
blackcat4866
10-12-2015, 11:39 PM
If you can get a measurement between intervals and specific colors affected, I can give you a more specific answer. So far it could still be one or more of the drums, one or more of the developing units, or fuser. I like "orange screws" thing. I've found that a few times myself. =^..^=
CrapAimer
11-02-2015, 04:49 PM
Many thanks for the replies, it was the orange screws all sorted
George
