habik
10-09-2015, 10:38 AM
Hello
Have a interesting issue. Recently had issue with C451 not printing from MAC any jpeg turned out to be network after we swapped the machine for C650 to prove to customer that it ain't the machine. We put C650 which was perfectly fine in workshop in the situe and got called again for bad connections etc eventually jamming a lot with the codes such Jam 7542, Jam 3201, Jam 3001. Could not believe it, went there, disconnected finisher and bridge, swapped sensors, cleaned rollers in eject section. Tested worked. Got called again next day for same jamming. Re-installed drivers, trouble reset the machine, replaced eject section with sensor from working machine + sensor&flag that sits below fuser. Machine worked for a day and client wanted it out. Next day colleague took fresh paper from the office and yes it was jamming with our paper J32-01. We had to pull the machine out and when brought back to workshop ... not a single time the bastard jammed.
I am bamboozled by this..I am trying to get the machine to jam and recycling the same paper over and over and it just won't jam. Found even some really old A3 and it works just as fine.
Was send a bulletin for intermittent J-3001 exit Jams C451 C550 C650 for one way bearing but would that fail me in the office also?
Just in case I ordered the eject drive unit (which has a significant wear on one of the bushings) will post picture soon.
The oneway bearing in eject assembly.
Anyone had something similar? Machine is approaching its 1st million and has Firmware R5
Many Thanks
Many Thanks
