View Full Version : Konica Minolta C220, 280 toner near end message
Alex1
10-13-2015, 02:21 AM
I need help with going into service mode and disable the near life and toner near empty message display settings.
how do I locate the settings please
allan
10-13-2015, 05:43 AM
Service mode -> system2 -> unit change.
If you initialize the engine data the toner levels will all show full.
Alex1
10-14-2015, 04:35 AM
Thanks for that. How do you initialize engine data??
splblazer91
10-14-2015, 05:00 AM
I think he is just warning you. You dont want to initialize the engine data if you dont have to.
Alex1
10-14-2015, 05:33 AM
I went into service mode as explained in the previous message I turned off toner low warning and the cyan still shows low. So I might have to initialize engine
Hansoon
10-14-2015, 05:47 AM
http://www.copytechnet.com/forums/konica-minolta/101222-bh-c-280-toner-empty-indicator.html
Hans
Alex1
10-14-2015, 05:56 AM
Hans
I appreciate the link you sent but I still don't know how to initialize the engine or manually feed toner in service. Can you please help
Hansoon
10-14-2015, 06:04 AM
You have a PM. Cannot post the Service Mode procedure here in the open.
Hans
copier addict
10-14-2015, 01:29 PM
Where is the toner showing low? Do you mean there is an actual message say replace toner. Or are you talking about the bar graph that shows toner level?
Alex1
10-14-2015, 01:44 PM
The bar graph shows low, once you install new toner it keeps showing low on the bar graph
copier addict
10-14-2015, 01:50 PM
You have to wait until the machine tells you to replace toner on this model. Just live with it. It isn't hurting the machine when it displays low toner on the bar graph. Next time wait until there is a message telling you to replace toner.
allan
10-14-2015, 03:59 PM
I you really really want to you can strip and vacuum the hopper.
If you initialize the engine data you need to redo gradation adj.
