View Full Version : Error Code FS 3460 ERROR 3200
brotherlarry
10-16-2015, 12:34 PM
Customer called with a system error code 3200. looked it up Ughhh check cables then replace scanner. (F#$K) has any body seen this and what did you do? Machine has 40k.
darry1322
10-16-2015, 02:03 PM
I've got a FS3140 in the shop right now with 140K. Sales wants it ready for resale. Everything looks OK except I looked at the Error Log and found 99 C3200s in history. 8 in the last 1000 copies.
I haven't looked much beyond that yet. Plan on giving the optics a good cleaning when I get a chance.
Kyo fan
10-16-2015, 03:11 PM
Don't replace anything. Just give optics (mirrors and lamp) and the top glass (upper and bottom side) good cleaning.
kyogenius
10-16-2015, 03:41 PM
As kyofan rightly said just clean the optics ,and dont forget the white strip on the glass, just make sure its clean and you are done!
brotherlarry
10-22-2015, 02:14 PM
Thanks everybody re-seated ribbon cable and it went away. Ugh snap on covers.
subaro
10-22-2015, 03:02 PM
just a note here. hope you cleaned and lube the scanner rail. they get sticky after a while and it can code out again.
