View Full Version : kyocera km-2550, scan to folder
magtech
10-19-2015, 03:14 PM
Hi,
One of my customer update his server from 2008 to 2012 and he his not able to scan to folder anymore.
All the settings are the same and the machine do not recognize the pc.
Do I need the Scan File Utility ? Because the scan utiity on the kyocera web site only supported until Vista ??
what can I do on this case ?
Any help will be appreciate
blackcat4866
10-20-2015, 01:22 AM
By deduction, I'm going to conclude that your customer is scanning to SMB until recently. Up to WinXP the standard port for SMB communication is port 139. Win7 and up, the standard port for SMB communication is port 445. Older Kyoceras did not have the option to select the SMB port. So there are two simple ways to communicate via SMB:
1) define the port in the IP address, for example: 192.168.1.200:445
2) Open up port 139 on the recipient PC or server.
eddie110171
10-20-2015, 04:44 AM
Kyocera has not supported any operating system after windows 7 with scanner file utility. Having said that I can tell you we have used scanner file utility on windows 8, 8.1 and 10. Make sure you use version 4.11
Santander
10-22-2015, 02:24 AM
From your description of the problem the customer is scanning to a folder on the server. When you shared the folder did you use the Advanced Sharing? There is a difference. When we setup a scan folder on a WinServer by default we always use the advanced sharing. With the heightened security in WinServer 2008/2012 a simple share will not give you access to the folder while advanced sharing will. We also always check the security tab as well to make sure the user account has at least modify rights, we normally set it to full control.
Leebs14
10-24-2015, 07:58 AM
Whilst I am sure all the above advice will work. I had this exact same fault on a Ricoh MPC2550, SMB Scanning worked fine until they upgraded to Windows server 12, then it stopped working. I upgraded the network firmware on the Ricoh, didn't change anything else and it's all back working again.
