View Full Version : bizhub 222 artefacts
adrianG
11-05-2015, 03:23 PM
Hallo,
I have a problem with bizhub 222 machine,a bunch of strange artefacts appearing on paper on printing and copying also.
31179
this will ocur on every pages
Thank you!!!
Copier Dork
11-05-2015, 04:23 PM
I have seen this several times before, and I believe that your charge corona is arcing to the drum surface.
This could be caused by several things:
-broken CC assy (grid is loose)
-worn drum shaft (s)
-bad DS rollers in the DV unit. <-Most likely
There is a mod available for the DV kit which replaces the all plastic DS rollers with a bearing roller.
Part #A1UDR90100
The kit includes 2 new DS Rollers as well as some new style spacers and end bushing for the mag roller
Hope this helps
Trevor
copyrooks
11-05-2015, 09:57 PM
My guess is replace the developing unit, along with the developer.
blackcat4866
11-05-2015, 11:32 PM
Drum arcing to: a) grid, or b) developing roller. =^..^=
adrianG
11-06-2015, 06:02 PM
thank you all,i will try those when i get to my client office.
Don N.
11-10-2015, 02:48 PM
Is the drum scored in the right side where the white trans roller finger contacts it? Are there upgraded dv collars on mag roller? Is the mylar torn at end of mag roller? How old is trans roller? You can take some, not all shims out of trans roller to prevent scoring, especially on rear side. New dv unit is about $100 + dv. Drum r/b kit & new t. roller & done for under $200.
Sent from my Nexus 5 using Tapatalk
