View Full Version : bizhub 211
Orion2010
11-23-2015, 10:11 PM
hello to all,
i have bizhub 211 i change drum, blade, developer , i copy 50 page and displayed this problem 31333, when i spin with hand it clean, but when put in machine does clean. any idea ?
thanks
copier addict
11-24-2015, 02:49 AM
It looks like it is pulling dev. Check drum ground and grid.
Hansoon
11-24-2015, 03:47 AM
Looks like the toner recycling isn't functioning. Have a look at the little gears which drive the recycling screw and see also if there is compacted toner in the pipe. Likely there will be noise too from popping gears.
Hans
Orion2010
11-24-2015, 07:05 PM
Hans
you say to change toner?
copyman
11-24-2015, 07:57 PM
Did you run F8 after installing drum & developer?
Orion2010
11-24-2015, 08:12 PM
no i dont know how?
