View Full Version : CQ DU-105 vs DU-106
This two drums are the same.they have the same material safety data sheet.
Is there any one that had tried to instal in konica c1060l drum du-105?
andyf424
12-08-2015, 10:52 PM
I too have asked myself this same question. Curious if anyone has done it though. Kinda like the du-102's somebody had to try a du-104 to find out they work.
Bizhub
01-06-2016, 02:52 PM
Snap the pin off and it will fit and work
31647
ragnarok
10-21-2016, 09:57 AM
31647
Hello! Can you please post a bigger image :)... can't find the bloody pin...
Toxic
05-02-2017, 12:52 PM
Hi,
Somebody figure out what is different between DU-105 and DU-106 and will DU-105 work on C1060L?
Tech Helpdesk
05-02-2017, 01:46 PM
If you look at the image closely you will see a hole at 10 'o' clock that is where the pin used to be, by removing the pin you can use the drums on C1060l no problem.
