View Full Version : C451/550/650 webtool time out
On all installation the last few month i have discovered that when you are using webtool the machine disconnect after very short time. :confused:
any ideas where this timer is set up?
nmfaxman
06-11-2008, 12:52 AM
Administrator mode.
Default code is 00000000.
Look for timers and set them all to 240, except for panel reset time.
konisolver
06-12-2008, 03:29 AM
There is no way to set the timer for this timeout. The only solution for this is to log-out and make sure to select HTML instead of flash. This also eliminates the "socket error" on the screen.
Sounds like an ok solution, thanks :cool:
