View Full Version : Bizhub 423 series fusing rollers
SmellsHot
12-10-2015, 08:32 PM
Anyone find a source for a UFR on this series? They wear so damn quickly.....and there killing my maintenance rev
Hansoon
12-10-2015, 08:49 PM
Call Hans: touchpanel[at]rex-technika.com How many pcs would you need?
We produce these:
blackcat4866
12-11-2015, 01:16 AM
Correct me if I'm wrong Hans, but I seem to recall that the bizhub 350 hot roller fits. So do the HR claws from the bizhub 500 or 501. =^..^=
Hansoon
12-11-2015, 05:05 AM
Yes Cat, its the same as is also with the UFR from the old Di3510. All are the same. We developed a roller which has a much better Teflon surface. The claws I don't know cause we never have to change them strange enough.
Hans
SmellsHot
12-17-2015, 01:02 PM
We produce these:
What yields are you getting out of your modified rollers?
I'd take a dozen if the price is right :)
Hansoon
12-17-2015, 01:35 PM
We ourselves are having machines with up to 130K without showing substantial wear until now. I expect them to reach easily 200K or more.
Drop me a mail than I prepare you an offer for 12 pcs.
Hans
copier addict
12-17-2015, 01:55 PM
Once we switched back to OEM toner we doubled the life of the UFR on these machines. I think it has something to do with the fusing temperature of the toner, so it sticks to the paper rather than sticking to the roller and then being picked up by the thermistors and sep claws and scoring the roller. We also don't get the wear ring on the drum as early as when we were using crappy aftermarket toner, and we tried quite a few suppliers, none of them were any good.
ni311
12-17-2015, 07:23 PM
Too bad KM don't offer these rollers as parts, you have to change the whole unit... from what I know, the Katun rollers are no good...
CraigW
12-17-2015, 09:07 PM
The 200-350s would go 400-500k without problems.
223-423s are lucky to make it to 1st PM without streaks appearing.
CompyTech
12-17-2015, 09:35 PM
Agreed.. Though I've been fortunate enough to warranty a few fusers through KMBS via the Y&PPP.
srvctec
12-24-2015, 12:25 AM
We use rollers from Image Supply, I think. Part # PP2227U or close to that- just going off memory. Getting 200+K out them which has been better than OEM KM.
srvctec
12-24-2015, 06:03 PM
Actually might be Precision Roller and the number on the box is 06601.
