Error 5357, i know it is cooling fan. Because at service manual is not clear wherethis fan is . Is the fan i noticed in the attached file?The one over the upper right side of PWB box.
c250 e5357
Re: c250 e5357
i think you will have to remove the cage (the metal frame which holds the circuit boards) to see item 8Comment
Re: c250 e5357
it seems to me, your image is showing item 7 which is closer to the back panel of the machine - you will notice item 8 is tilted and sits closely behind the color developing motor, deeper inside the machine
Re: c250 e5357
item 8 is tilted, it is larger, it is closer to the middle of the machine and it is located right behind the developer motor, and the developer motor is definitely behind the cage - it seems item 8 is tilted so it can move air over the top of the cage
should only take you 10-15 minutes to remove the cage though, it's not that big a jobComment
