View Full Version : Konica 222 erase old information
Is there a way to erase previous owners info all at one time instead of one at a time thanks
emujo
12-15-2015, 06:32 PM
HDD format will erase any address book info, SSL cert and associated settings, and any user box info...Not much else is retained after power cycle on this model. Emujo
Motormount
12-15-2015, 10:35 PM
In the admin settings, under HDD I think, is an "Overwrite All Data". Overwrites HDD when present, and erases all client data.
peter42
12-16-2015, 07:02 PM
If a HDD is present you can erase anything in service mode.
if not, you have to delete any stuff in admin mode.
best to do that, with pagescope.
Have your prefered IP to the machine, connect to it,
start Browser with machine adress go into admin mode and
you can delete all data btw. reset to default settings, that helps.
greetings peter
