bizhub 20, lost settings
  • giddyupngo
    • Oct 2014
    • 109
    [Misc] bizhub 20, lost settings
    Hi,
    I was working on a bizhub 20 because of occasional duplex jams, when I came back to the machine the next day, the IP address was set to DHCP so it pulled a new one, the sleep setting was back to default, and all the fax one touches were gone. I talked to Konica Minolta, and they think it is the battery assembly. A small battery pack that functions like a CMOS battery on a PC motherboard, which powers a memory chip to hold the settings. The battery could have been bad for a while, but when I power cycled it that could have reset some settings. They never turn it off, it just goes to sleep, so by power cycling it I could have inadvertently caused this. Just wondering if anyone else has ever dealt with this or seen this before. I know this is a re-branded brother machine, so I thought of searching under the brother model number, does anyone know the equivalent brother model number?
    Thanks in advance
  • ni311
    • May 2008
    • 658
    Re: bizhub 20, lost settings
    I believe it is BROTHER MFC-8460N
    Konica Minolta Error Codes - Explanations and Solutions
    • giddyupngo
      • Oct 2014
      • 109
      Thank you, that is very helpful.
      • ni311
        • May 2008
        • 658
        No problem, Happy New Year to all fellow technicians!!!
