View Full Version : Miscellaneous Toner Need To Replace Bizhub C550
Naveed Shahid
12-25-2015, 11:06 PM
Hello every one
I am facing problem on bizhub c550 yellow toner need to be replaced toner is new machine detecting new cartridge and showing full but machine not working i changed pcb board but problem same i changed yellow toner hopper i checked toner drive section but problem same
any solutionThanks in advancee
mo0651
12-28-2015, 02:13 PM
Is the toner popping out of the holding claw in the back?/ May be full of toner spilled out, or worn out. We have replaced these before.:cool:
Imsdal
12-30-2015, 08:09 AM
Hello
When you insert the drumunit into the machine the number 9 on the picture must open and if doesn´t open it wont come toner inside the unit and will alarm the you need toner and the springs with the nr 8 can also come loose.
Cheers
Imsdal
