View Full Version : KONICA MINOLTA C253 printing Issue
junidexy
01-05-2016, 01:14 PM
I have issue in my Konica Minolta C253 Copier, when I get print or Photocopy the image come with full of lines, image is attached in the mail
can anyone help me what might cause the problem
allan
01-05-2016, 01:49 PM
Have u reseated all the IU's?
Looks like fine lines?
Jessetech
01-05-2016, 04:37 PM
look at your DV unit, is it fully covered or and your drum,
allan
01-05-2016, 06:24 PM
What is that? copy of something or a print?
matthewr88
01-05-2016, 10:06 PM
I would say contact between either drum and belt or belt STR roller (more likely drum / Belt)
have u tested what result b&w vs colour gives you
what does a blank photocopy look like.
blackcat4866
01-05-2016, 11:52 PM
The difficult part for us, is that we have no idea what that original was supposed to look like. Is the blue background part of the problem? Are the bands crossfeed part of the problem? It's probably safe to guess that the thin void lines in the feed direction are part of the problem.
Not knowing anything about your original image, I'm going to go out on a limb and suggest replacing a cyan IU, and cleaning the laser slit glasses. =^..^=
emujo
01-06-2016, 01:39 PM
Along with some more details, I would like to see the results of internal test prints, and possibly a scan job..Looks to me like image processing is whacked. Internal test prints are stored and may not have to be manipulated when printed...might help troubleshoot. Emujo
wseyller
01-07-2016, 01:01 AM
Check the ribbon cables for the print head that connect to printer control board.
Sent from my XT1254 using Tapatalk
