View Full Version : C284e - J32-01
Hi dudes,
did anyone had this random J32-01 trouble with a C284e ?
In a duplex job, the first sheet goes out of the MFP instead of going upside of the exit unit.
I've replaced SD3, tried to cut both springs in the paper exit unit(solenoid SD3 + gate) but it only works few days.
no idea where to look for.
allan
01-08-2016, 10:38 AM
http://www.copytechnet.com/forums/konica-minolta/91900-c284-jam-code-3201-a.html?highlight=3201
Looks like it is a sticky noise damper on the gate.
i had cut the spring guide but definitely not by half.
I will try and tell you.
There's a bulletin on the KM site about inserting a 2mm thick mylar between the end of the solenoid plunger arm and the wall for this model.
I tried (not with a mylar), but still doesnt work properly.
Could you send me this TB ?
allan
01-08-2016, 04:38 PM
Do you have the bulletin number?
Sorry, the bulletin number is KBAO 1500433.
srvctec
01-08-2016, 09:03 PM
We've replaced the sensor on a few machines to fix same jam code also.
update : looks like working with all your help thanks.
if anyone could send me this KBAO 1500433, i dont have it in my euro km database
Just wanted to update this thread. We still see this problem and they have come out with a new part to fix it. See the attachment for the bulletin.
38121
gareth577
11-09-2017, 10:54 PM
38121
Are you able to PM me the tech bulletin regarding the j32-01 code, I'm unable to view it clearly within the forum page
Sorry,
The part number is A7PU890800 Holding Part.
