View Full Version : Error Code Bizhub 601 false jams in finisher?
Joe Foe from Buffalo
01-08-2016, 08:59 PM
After machine sits no rhyme or reason how long sometimes from 3 minutes upwards to half an hour will say it has a jam at finisher entrance. Open finisher nothing close will say jam in fuser area. Open it nothing resets jam. Will post Pics of what it says asap. Almost seems heat related
vapesenberg
01-08-2016, 09:00 PM
Clean all 5 punch unit sensors. Check LED'S on FN control board.
Sent from my SM-N900V using Tapatalk
antone
01-08-2016, 09:04 PM
Disconect
antone
01-08-2016, 09:05 PM
Disconnect 3 hole 👊 punch all together
01-08-2016, 11:54 PM
I maybe wrong..but I don't think it has a hole pucher
antone
01-09-2016, 02:07 AM
Disconnect finisher all together...see what happens!!
blackcat4866
01-09-2016, 02:17 AM
Jam codes? =^..^=
antone
01-09-2016, 02:19 AM
Ya what the codes
01-09-2016, 02:37 AM
I was going to disconnect the finisher to test if it went away but ran out of time. Short video of what it does after I gets a false an can reset it buy opening finisher then machine an pulling transport/fuser section out.
https://goo.gl/photos/Nkdsxsc4aLDpqFkc6
antone
01-09-2016, 02:46 AM
You need to go to Dip sw....and turn 11-7 on this will give you a TROUBLE code...this will bring u to the problem
allan
01-09-2016, 03:05 AM
There is a sticky actuator damper in the exit section on the machine, remove the small sponge pad.
Remove the side cover and the exit section 5 screws and a connector look for the sensor and see if it sticks.
antone
01-09-2016, 03:09 AM
Go service mode....system 2....u will find Dip sw sett
srvctec
01-10-2016, 02:22 AM
Disconect
Ya what the codes
Seriously!? Are you for real? Trying to get your post count up for some reason?
01-11-2016, 03:10 PM
Back on machine. Has no hole punch. Did disconecting fs-925 finisher problem goes away. Can't find any thing causing this...
allan
01-11-2016, 03:22 PM
Check the jam code under counter in service mode.
01-11-2016, 07:11 PM
In service mode counts jams as jams...at #3206 fixer/fuser
allan
01-11-2016, 09:10 PM
Change out PS37 on the main body and PS1 on the finisher. Check that PS37 actuator falls back easily.
01-11-2016, 09:41 PM
looking for the part #'s of both asap..may need the parts catalog if someone wants to share or trade for one
01-13-2016, 04:47 PM
GRRR! What happen to the post showing a link to the parts catalog?
allan
01-13-2016, 05:01 PM
Use State Conformation do the sensor check. Have you removed the side cover on the machine?
01-13-2016, 05:15 PM
yes I have done this. Some posts are missing...! Wondering why.
