View Full Version : Konica C220 - Email subject
jonbonse
01-19-2016, 08:05 PM
Hi All
I have a used KM C220 with someone else's company name in the subject line when you scan and send emails from it.
When I log onto the copier via explorer as administrator, the email subject line is blank!
Please can anyone help me clear this old company name?
emujo
01-19-2016, 08:49 PM
Admin/Administrator Machine Settings/Admin address and Machine address. Subject line has nothing to do with from address. You can always do a network init to clear this info out though. Emujo
jonbonse
01-19-2016, 08:56 PM
its not the 'from' address that's the problem, it's the subject line of the email (or the message it puts in the email subject line)...............
emujo
01-19-2016, 09:08 PM
31754Subject line info is programmed through the public user, not admin...Emujo
EarthKmTech
01-19-2016, 10:58 PM
the current settings have been saved as default in scan mode - even if you change the subject in pswc it will stay as it was set previously at the panel. Change it in scan mode once corrected and then re-save the current settings as default.
Had this yesterday and was reminded of this quirk.
jonbonse
01-20-2016, 12:54 PM
Thanks!
How do I save as default once changed?
scan/fax mode -> communication settings -> email settings -> subject -> write yours. -> "close" ->
utilty/counter -> user settings -> scan/fax settings -> default scan/fax settings -> current setting -> "OK"
emujo
01-26-2016, 08:24 PM
Good answer...think I'm going to like JDR...Emujo
