View Full Version : CQ km-c364 cyan dev
ash_572
02-08-2016, 07:49 PM
i have a km-c364 that keeps losing cyan developer after 4-5k prints. as a result i start to get white diagonal lines
the drums look clean and good.
all the rest of the colors are perfectly fine.
i haven't got much experience with this model and your help is very appreciated
thanks
copier addict
02-08-2016, 08:32 PM
Usually when this happens it is the HVPS.
Hope this helps
richmods
02-08-2016, 08:46 PM
thanks
Can you post some samples and can you also tell us what you have done so far?
habik
02-08-2016, 08:50 PM
Have you checked the Image adjustment settings? Any odd defaults?
ash_572
02-08-2016, 08:54 PM
the only that i have done so far is changed they cyan dev unit.
i havent checked any settings in service mode.
machine has done less than 100k colour
ash_572
02-08-2016, 08:55 PM
Hope this helps
high voltage power supply?
copier addict
02-08-2016, 08:58 PM
Yes
ash_572
02-09-2016, 08:51 AM
Yes
Hi
can you please send me the part number?
EarthKmTech
02-09-2016, 09:53 AM
have you tried a new toner?
This issue has been discussed to death in another thread already.
I practically rebuilt the machine and nothing made any difference.
2 possibilities were, initialization of the machine or replacement of the toner cartridge and vacuuming the hopper
these were the last 2 things i tried after many cyan devs and drums were destroyed - it has now gone a few toner changes and even a whole drum life since the last failyre now.
ash_572
02-09-2016, 12:51 PM
Hi
I have not tried a new toner cartridge, eventhough its genuine
wseyller
02-09-2016, 07:57 PM
I personally haven't had those calls but got an email from manager the other day to all techs that were having problems related to cyan & magenta dev units on the E series. Similiar to the issue you are having.
folukems
02-10-2016, 02:35 PM
hope you are using the oem toner? and your earthing system is perfect
hotfuser
02-10-2016, 06:10 PM
check out a link i started over 15 months ago
C224e/C284e/C364e/C454e/C545e cyan dev unit problems (http://www.copytechnet.com/forums/konica-minolta/94088-c224e-c284e-c364e-c454e-c545e-cyan-dev-unit-problems.html?highlight=cyan+dev)
im glad someone else seems to be having a problem.
Tech Helpdesk
02-12-2016, 05:02 PM
I see K-M are moving at their rapid rate !! One thing worth checking is the state of all consumables even if they are not related to the fault. For example a drum could be causing issues or even the transfer belt. Hotfuser is the one to talk to regarding this problem, but you MUST make sure everything is well under life to have even the slightest chance of fixing this. Just to let you know we reset our dev units and are running them to death and as long as we change the drums at life or just over.
For us it makes sense to fit a black drum (when at life end) in every socket on the machine and chip them so the machine knows they are new and reset the dev units and let them run.
