andyf424
02-11-2016, 08:17 PM
Has anyone here done the adjustment of the multi-feed detection board on a pf-602? I've got a c1070 with a pf-602 and it's throwing constant 1610 jams. There is not 2 pages at the sensor but it's throwing codes as if there is. I recent replaced the PFU-drive board for an unrelated issue and now this is happening, I'd rather not replace the sensors with out re-calibrating the sensors.
Service manual says
Insert a sheet of paper [1] (part number 65AA995##, fusing adjustment paper, A3 16 sheets) while you turn the knob PF4 [2], and close
the jam processing guides PF2 [3] and PF5 [4]. (you can also use 200 g/m2 to 300 g/m2 paper.) (PF-602m).
Am I supposed to use 16 sheets of 200-300 or just one? I find the engrish on this portion of the manual to be pretty confusing. None of the techs I work with have ever made this adjustment, wondering if any of you folks had some advice.
Service manual says
