TerenceH
02-15-2016, 08:11 PM
I am getting a 6755 error code while the DF-704 is installed. I have replaced the entire document feeder (twice both new out of the box), and have replaced the MFP, I have flashed new firmware, reset error codes, and it still errors out. However if i leave the adf up while it is booting there is no error and everything works just fine. no image quality issues the adf feeds just fine, no issues at all until I try to reboot. My theory is that it is in the CCD not the CIS. The clamp values I am getting are all 0, and the gain values show everything is in an acceptable range except the B0, and BE those are around 50 (service manual shows that they should be a minimum of 70) everything in the service manual points to the CIS/ADF. If I remove the ADF and turn it on the values are still lower than what they should be but it does not error.
