View Full Version : Garbled print on Bizhub 222
Solotime
02-16-2016, 05:57 PM
Anyone seen this issue?
srvctec
02-16-2016, 06:09 PM
Reseat all plugs on main boards. Reseat the memory and/or replace it.
habik
02-16-2016, 08:13 PM
MFPB?
Give the connectors and memory a try as Srvctec suggested.
Solotime
02-17-2016, 03:35 PM
I tried this late yesterday. After that, when I went into the admin mode it immediately tells me to format the HDD. So I started the format process and it did nothing for 2 hours. So I shut it down, went into service mode and un-installed the HDD. So far it is working fine. Will update once we get more time with it.
allan
02-17-2016, 04:01 PM
Did you attempt a physical or a logical format?
Physical format can take a while.
Solotime
02-17-2016, 05:36 PM
I was not in the service mode and it did not give me the option. I am thinking hard disk errors. I was simply going into the Admin Area and the screen came up saying due to a recent change (I made none) that an HDD format was required. No options were given.
MINOLTAMAN1
02-18-2016, 12:33 AM
I've seen this before, but it escapes me. Is this thru the ADF? If so, does it do it both LEF and SEF? I'm trying to jog my memory.
habik
02-18-2016, 11:21 PM
Go to Service and do as Allan suggested, could have been done over night if customer is happy with it. It could be faulty HDD. Is the firmware updated?
HuronMan
02-23-2016, 12:52 PM
It's the mfbs board.
Solotime
02-23-2016, 09:16 PM
So far the machine has been fine since "uninstalling" the HDD in the service mode. Only been 4 or 5 days but so far so good.
