View Full Version : bizhub 250
touch panel didn't work (keys worked) . two plastics that screws screwed were broken . I qlued the plastics also replaced touch panel (because it fell down and broken) . But when i use it have smae problem . Is there anything i must take care?
allan
02-17-2016, 03:53 PM
Change the panel that is the only fix i know.
Hansoon
02-18-2016, 07:16 AM
If you replaced the touch panel with a new one (used will NOT work well, cause having the same inherited problem from the old series) and still not working, than I would clean the rim where the touch panel sits on. Often crud is coming between the touch panel and the underside of the control panel cut out. Did you do the calibration BTW?
Hans
Hans
How can i do calibration BTW ? Only keys are working not touch panel.
JR2ALTA
02-22-2016, 03:13 AM
Did you install the touch panel upside down like I did once?...doh!
I installed it right.
copier addict
02-22-2016, 01:55 PM
Then try another touch screen. It could be defective.
