View Full Version : bizhub c350, c352, no fiery, need print drivers for windows 7, 8 10 32bit and 64bit
n25an
02-19-2016, 04:22 PM
I am looking for print drivers for the following machines...
The machines in question have no fiery attached...
found a universal driver but these models aren't listed...
wondered if the a3 color driver listed in the compatibility list for the universal driver will work with these models...
please advize...
note most drivers out there are for the fiery for these models...
Blizzoo
02-19-2016, 05:57 PM
Download Centre - KONICA MINOLTA Europe (http://www.konicaminolta.eu/en/business-solutions/support/download-center.html?ref=dlptl)
Check "Include discontinued products" under Choose Product and you will find what you need.
Good luck
n25an
02-20-2016, 09:24 AM
Good luck
tried that... every last one is for the fiery... it even says its a fiery driver when installing it... when I install I get garbage prints...
blackcat4866
02-20-2016, 01:33 PM
On a machine this old, the best you can hope for either a universal driver from KM or a mismatched driver that has limited functionality. Most recently I had some success with an Oki C5200 and Windows 10. I started out with an HP Universal Driver. The printer would display " ... wrong data ...". Then I found a more recent Oki model and searched for drivers. I found a PCL5, PCL6, PS2 and GDI. Using the "New Driver ... " button on the Advanced tab of the print queue, I selected the .inf file of each, until I had success with the GDI driver.
You won't harm the printer by sending wrong data. The worst result might be 1000 pages of PostScript error commands. =^..^=
Mr Spock
02-20-2016, 02:59 PM
Self-Help Product Support | Konica Minolta Business Solutions, U.S.A., Inc. (http://onyxweb.mykonicaminolta.com/OneStopProductSupport?appMode=Public)
You may need to try the vista or windows 8 driver since they do not list a windows 10.
peter42
02-20-2016, 06:06 PM
Try Hp 5000 driver pcl ,thats works with ricoh, KM and Hp also.
greetings peter
paulrid
02-20-2016, 08:20 PM
Try
Download Centre - KONICA MINOLTA United Kingdom (http://www.konicaminolta.co.uk/business-solutions/support/download-centre.html)
you should find them there.
n25an
02-20-2016, 08:41 PM
greetings peter thats good for a black and white km but whats a driver that works for color bizhubs thats compatible...
n25an
02-20-2016, 08:44 PM
Try
took a look... its still fiery drivers... unless i am missing something
paulrid
02-20-2016, 09:03 PM
I select multifunction colour then c352 and under driver I see the pcl6 version released in 2008 but if I change to Windows 10 it's only universal driver but I think that should also work.
n25an
02-20-2016, 09:06 PM
that makes me wonder.... does each brand have a driver... not the universal driver.... but a driver that is compatible with all models in that brand... just a thought... keeping in mind that some are black and white and some are color...
