View Full Version : CQ KM C220 Faded to blank output
bayshoreoe
03-02-2016, 04:01 PM
Customer has this unit and complaining of light going to blank prints. Printed a report from machine and it was blank. Made color copy to see if all were blank or only black. copy came out fine. printed report again, fine. Customer called a few hours later, blank output. swapped black and cyan drums to rule out drum. After a few(50) or so prints, got light and went blank. DV brush is good.
Any ideas? Not that familiar with KM color.
Brian
acusso1234
03-02-2016, 06:23 PM
Hi. Try changing the K developing clutch.
Service manual explains how to do this.
Your black developing unit is not rotating due to that clutch that probably is slipping.
neil greenhough
03-02-2016, 07:28 PM
Brian
Yes accusso is right. The dev clutch is slipping. Changed one today, one of many!!
bayshoreoe
03-02-2016, 11:58 PM
Would anyone happen to have the part number for the BK DV clutch?
JR2ALTA
03-03-2016, 12:16 AM
Weird, I've never had to change a DV clutch
allan
03-03-2016, 05:32 AM
I have had the drum clutch fail. need to change the entire drive.
acusso1234
03-03-2016, 06:09 AM
A0EDM20000 CLUTCH
bayshoreoe
03-03-2016, 07:26 PM
Thank you all so much for the assistance
hotfuser
03-04-2016, 09:27 AM
the wire cracks at the joint of the clutch.
KM put a bulletin up after we advised them of what the issue was.
They also released the clutch as a seperate part due to the fact it didnt come as a single part only as a complete drive.
