View Full Version : Miscellaneous ic304 with c6501
pudgi300
03-02-2016, 05:32 PM
Hi,
We are looking to buy Konica IC304. Will it support fs521,sd506 and newer PF. It has ver 2.1 on the IC304. Or will we need to get a IC304 PLUS. Thanks for any help
Later
pudgi300
03-04-2016, 04:02 PM
Maybe have to ask question a different way. If i have a Konica c6501 with IC-304 with ver 2.1 will it support a fs521,sd506 or do i have to have a IC-304 PLUS ? Thanks in advance for help answering this question.
Synthohol
03-07-2016, 11:18 PM
it works just fine with the entire yacht-worth accessories you can attach.
Mick01
03-08-2016, 04:04 AM
Hi,
IC-304 is compatible with that machine configuration.
pudgi300
03-08-2016, 03:38 PM
Thanks Mick for the information to confirm my findings. Matter if fact just yesterday i found the Konica firmware list for Creo IC-304. Looks like the same software for the IC304 and IC304 PLUS. Just the Plus has bigger hard drives and faster processor. So i think we will be able to setup the IC-304 with the Konica c6501. What messed us up was the Rip we got was advertised as a IC-304 PLUS but when we got it it was just a IC-304 with ver 2.1. We were not sure the if the IC-304 would suport fs521.sd506 and pf. So thanks again for your help. Been doing copiers and printers for 43 years (IBM,Kodak,Danka ) and last 18 years as independent tech for print shop. It can be tough some times when you need information and can't access Konica databases.
Later Pudgi300
