Hi all,
I found the issue of username which have the uppercase letters and lowercase letters under the external server authentication the following.
Example of username on active directory = abc123
1. When user login on the machine or verify with driver for the first time with username = abc123
Result: It can login or verify with driver and then the machine will have username list appears is abc123 (Enable username list).
2. Repeat steps 1. but changes uppercase letters and lowercase letters or both.
Example:
Abc123
abC123
aBc123
Result: The machine will have username list appears are abc123,Abc123,abC123,aBc123
Username list all can be login the machine with same password. (bh423,bhc224e not have this issue under same environment.)
Thank you,
Example:
Abc123
abC123
aBc123
Thank you,
