Sam Tofu
03-08-2016, 04:32 PM
With different machine same model same code, we have narrowed down this problem to the waste toner delivery drive assembly .
(About a year ago went through real head scratcher with this. error For ref here is link
http://www.copytechnet.com/forums/konica-minolta/72178-c552-odd-issue-error-c-2204-a.html
It did end up being waste box/sensor related.)
HERE is issue now. On the last series of posts,, Earth KM Tech mentioned that this assembly is really easy to take out once the left side is off. Nothing in manual regarding taking out. I and the other Konica Tech are pretty able to just do whatever HOWEVER after taking a number of screw of, disconnecting a number of cables, and taking off the gear coupling connections from the from, I am just not seeing how this is just a few screws and comes out really easily. I am hesitant to just keep digging in further on this as EarthKM Tech mentioned it was just a few screws and real easy to pull.
Any further info suggestions, tips etc would be great.
TIA
TIA
