View Full Version : So how are the TASKalfa 4550ci, reach PM cycles, run good or ???
I'm thinking of picking up the service on a couple of 4550ci/5550ci , they have around 350-500k on with color and blk/white meters split about in half.
Is this a good box or should I stay away?
Will they make it to the 600k PM cycle?
How long will the fuser go?
Toner yields OK?
jhalfhide
03-10-2016, 09:39 PM
We found toner yields to be an issue so we stopped the service on our Kyocera's. Transfer belts and fusers seem to last forever if you run them to life though.
wholesaler
03-11-2016, 12:27 AM
Toner yields OK?
very rarely do they make it to the pm cycle but they warranty the machince for 600k so you can get credit for the parts that dont last the 600k
blackcat4866
03-11-2016, 12:35 AM
The rollers fail around 100K ... unless you sub in the standard Konica Minolta rubber. I'm getting better yields from them. =^..^=
Daveyboy
03-17-2016, 11:05 AM
We have loads of these and they go wayyyyyy past pm counts.
Only real issue we have is fuser jams when users use cheap paper and lots of colour.
Feed tyres are £30 a set and last 80 to 90k so worth checkeing the counts in 251
Cheers
Ctl-Alt-Del
03-19-2016, 01:08 AM
I'm a fan of the machine and an even bigger fan of the newer xx51ci series, they are generally profitable units for us.
jmaister
03-29-2016, 07:05 PM
In comparison to TA250ci to TA500ci, way better.
Drum/developer rarely fails but the main charge tend to swell after 300,000 or earlier. Feed pulley as Blackcat said doesnt last til 300k.
Fuser tend to fail. Well, kyocera fuser tend to fail, its the norm.
Are there any differences between Taskalfa 4550ci and Copystar 4550ci ?
tmaged
07-31-2016, 07:49 PM
None at all. Change the badge & sim and it's a Kyocera.
jhalfhide
07-31-2016, 09:20 PM
Yep, as tmaged said they are exactly the same. As are Utax.
