View Full Version : C224 QUALITY PROBLEM
karim-tech
03-18-2016, 05:02 AM
hey every body some help plz
i have a quality problem with a KM c 224
for the test pattern shown in the first picture is with 2 level
the first 4 colors wirth the 255
and the second with 100
the problem is too light in the side with the red circl for the 4 colors
i have changed the transfert belt the fusing unit also the k DRUM but problem persisted
32258
32256
EarthKmTech
03-18-2016, 07:57 AM
since its all 4 colours I'd be looking at the second transfer roller first of all, is it pressing properly against the belt ?
Have you stopped the machine mid paper feed to see if the image is formed perfectly on the belt ? if it is, you can be assured its a second transfer issue.
karim-tech
03-18-2016, 03:13 PM
thx
EarthKmTech (http://www.copytechnet.com/forums/members/earthkmtech.html)
http://www.copytechnet.com/forums/images/statusicon/user-offline.png for the replay
i have changed the second transfert also and the problem persiste
i stopped the machine to creat a missfeed paper to check out the latent image created on the transfert belt and the image was with the same problem
thanx again
copier addict
03-18-2016, 03:28 PM
thx
thanx again
Did you clean the printheads?
karim-tech
03-18-2016, 03:54 PM
thx for the replay
yes i did for the 4 printheads
let me tell you that the problem is in the 4 test colors
if it was the printheads maybe will be just in one color
thax again
best regards
emujo
Have you double checked to ensure the shipping locks were removed from both sides of the X-fer roller? I've seen this bite more than a few techs thinking that since the string came out, the lock must be out also. If the image is being laid on the xfer belt the same way, then the issue has to be related to the print head, or x-fer belt. Emujo
kingarthur
03-18-2016, 04:36 PM
is the m/c level...
allan
03-18-2016, 10:16 PM
I have a similar problem on a C280 all seems fine second transfer and ITB replaced the machine is level the drums and DEV unit are all good. I changed the paper to SEF and the call is gone for months already.
Have you tried adjusting the transfer currents??
mo0651
03-18-2016, 10:17 PM
We had a c454 non e model with a similar quality issue. We had a bad printhead.
allan
03-18-2016, 10:22 PM
That is one of the few things i did not change?? I will try that when the call comes back...
gordonu10
01-05-2017, 04:43 PM
Have you tried cleaning the IDC sensors under the transfer belt?
what copy count have the developers done
have you tested a different developer unit
from the comparison pics all pages looks weak not just the edge
Synthohol
01-05-2017, 05:11 PM
I've seen similar issues when the floor tilts the copier towards the wall so all the DV bulk is in the middle to rear.
Put a level on the platen glass and see if it's off kilter.
DelawareJim
01-06-2017, 06:28 PM
Check the 2nd transfer assembly housing. In perticular, the 4 springs and 2 tabs that hold it onto the frame. Simply remove the whole assembly and reinstall making certain that the 2 tabs and all 4 springs go where they are supposed to go.
