View Full Version : Bizhub di2010
tgrqy96
04-02-2016, 11:12 PM
I have a bizhub di2010 that has been sitting for a while, upon boot I'm getting error code C0BA0
Any ideas?
allan
04-02-2016, 11:42 PM
C0BA0
Elevator Motor Ascent/
Descent Drive Failure
To reset open and close the front door.
tgrqy96
04-03-2016, 01:32 AM
Doesn't seem to have made a change. Still stuck on the same error screen
allan
04-03-2016, 02:58 AM
Its got a finisher on it right?
Remove it if you need to if one of the finisher bins are not set correctly this could happen.
darry1322
04-03-2016, 12:14 PM
You'll get this code if the exit trays for the finisher are not installed or if a tray is not level.
tgrqy96
04-03-2016, 05:40 PM
I believe I'm missing some hardware for the finisher bins,
So what all do I need to remove to remove the finisher?
It's not used, so removing it is the easy option.
I apologize, I have a technical background but zero experiance with printers. Just looking for the proper way to remove the finisher.
allan
04-03-2016, 09:07 PM
Open the finisher door and look for a square hole to poke your screwdriver in. It releases it, press in your screw driver while you pull.
The hole is about +- 10mm by 10mm.
Make sure the machine is switched off first.
