View Full Version : Miscellaneous KYOCERA FS-1028MFP
hello all my tech friends ...we have fs-1028mfp ...if we started copy all copy is white any copy ...good drum ..good toner pls any idea to sloved my problems
acusso1234
04-06-2016, 10:23 AM
Is your toner cartridge properly installed?
Can you see toner on the magnetic roller of the developing unit?
Try running sim 130
Tonerkiller
04-06-2016, 03:02 PM
The drum unit is not seated properly.
copier parts n.ireland
11-16-2016, 11:26 PM
had this a few times,can be the lsu shutter guard is sticking hence laser is not putting image on drum ,removing and refiiting drum cures,had a few springs off after removing side cover as well
kyogenius
11-25-2016, 10:01 AM
very true have encountered this problem on so many machines
