View Full Version : Login issues
cliffordf78.cf
04-12-2016, 02:11 PM
User name password Admin....sayscannonot login ....how can i change DNS settings ?
Sent from my SM-G900H using Tapatalk
MDR24
04-12-2016, 04:02 PM
What machine is it? Admin isn't the login credentials of every kyocera machine depending on the Model it could be a different password/username. Are you trying to login using the web interface or on the machine itself? Need a little more information if you want the right answer.
The information will be in the manual also.
cliffordf78.cf
04-12-2016, 05:56 PM
Wed interface .its say cannot log in
wragsdale
04-12-2016, 09:15 PM
I'm assuming "Wed" is actually "Web" interface and you're just trying to change your DNS server settings remotely. Admin access to the web interface should always be Admin:Admin if you're being prompted for both a user name and password, otherwise it should be just admin00 if you are only being asked for a password. If you have account codes enabled, you will see a user account login on the newer command center. If this is the case, you can click on Admin to instead be prompted for an admin login.
I could tell you for certain if you could let us know what model you're referring to.
Additionally, DNS settings can be changed from the panel.
cliffordf78.cf
04-13-2016, 07:14 AM
TA4500 i
