View Full Version : Jams 72 19
antone
04-18-2016, 11:59 PM
BH 1050....finisher jams in entrance ps 4 ..stops under senor I/0 mode used any usefull...tricks
Sent from my SM-N920V using Tapatalk
Mick01
04-19-2016, 08:00 AM
Hi,
So I assume that you mean by I/O you have checked that the sensor is changing state? It would be a good idea to also clean/replace the sensor as it may be intermittently faulting.
If so then it most likely is a drive issue (paper not making it past the sensor in time). Check and clean the conveyance rollers. Check the drive system,motors etc. Observe the drive operating when prints are being run to see if any drive issues are apparant.
good luck, hope this helps.
antone
04-19-2016, 08:23 PM
Hi,
Ok will do.....very hard to tell seams like it's OK
