View Full Version : Miscellaneous Installed place?
allan
04-19-2016, 03:32 PM
Hi there
I am trying to use status notification on a C280.
On the email it shows the IP and under "installed place" there is no info.
anybody know where this setting is?
Anybody have Savecom experiance?
allan
04-19-2016, 07:09 PM
Just throwing it back up there.
Synthohol
04-19-2016, 08:00 PM
i dont see anything about installed place.e, i get notifications all the time. out of paper, no toner, jam etc..
you can set the location under model name i guess?.
are you using some other software other than what works perfect right from the copier?
sorry if i misunderstand the question.directions below for a typical setup.
ebkit-text-stroke-width: 0px; "> 6.57 Network Settings-Detail Settings-Status Notification Setting
It will not be displayed when the following setting shows that authentication device is mounted.
[Service Mode] → → [Management Function Choice]
To notify status, notifications both by E-mail and by SNMP TRAP function can be set. For E-mail, up to ten IP addresses and one IPX
address can be set. For SNMP TRAP function, up to five IP addresses and one IPX can be set.
bizhub C360/C280/C220 I ADJUSTMENT/SETTING > 6. UTILITY(ADMINISTRATOR
SETTINGS)
I-114
6.57.1 Register Notification Address (IP Address)
(1) Use
To set IP addresses to which machine status notifications are sent.
Up to 5 addresses can be registered.
(2) Procedure
1. From IP address 1 to 5, select an IP address where settings are made.
2. Touch [Host Address].
3. Select , or and enter a host address.
4. Touch the Clear key and enter a port number within the range of 1 to 65535 using the 10-key pad.
5. Touch [Community Name] and enter a community name.
6. Touch [Notification Item] and set the items to be notified to [ON].
7. Touch [OK] and finish the settings.
6.57.2 Register Notification Address (IPX Address)
(1) Use
To set IPX addresses to which machine status notifications are sent.
(2) Procedure
1. Touch .
2. Touch [Network Address] or [Node Address] and enter an address.
3. Touch [Community Name] and enter a community name.
4. Touch [Notification Item] and set the items to be notified to [ON].
5. Touch [OK] and finish the settings.
6.57.3 Register Notification Address (E-mail Address)
(1) Use
To set E-mail addresses to which machine status notifications are sent.
Up to 10 addresses can be registered.
(2) Procedure
1. Touch [Forward].
2. From E-mail addresses 1 to 10, select an E-mail address where settings are made.
3. Touch [Edit E-mail Address].
4. Enter an E-mail address (up to 320 one-byte characters) using the keyboard on the screen and touch [OK].
5. Touch [Notification Item] and set the items to be notified to [ON].
6. Touch [OK] and finish the settings.
6.58 Network Settings-Detail Settings-Total Counter Notification Settings
6.58.1 Notification Schedule Setting
(1) Use
To set the schedule for informing the total counter value.
Two different schedules can be set for reporting.
(2) Procedure
1. Touch [Schedule 1] or [Schedule 2].
2. Select the reporting cycle from [Daily], [Weekly] or [Monthly].
3. When selecting [Daily] for the reporting cycle, set the Interval of day(s).
4. When selecting [Weekly] for the reporting cycle, set the Interval of week(s) and day of the Week.
[I]5. When selecting [Monthly] for the reporting cycle, set the Interval of month(s) and date of the month.
6.58.2 Notification Address Setting
(1) Use
To set the e-mail address for reporting the total counter value.
Up to three e-mail addresses can be set.
It can be selected whether to apply the schedule of the [Set Schedule] to each address.
(2) Procedure
1. Touch [Address 1], [Address 2] or [Address 3].
2. Touch [E-mail Address Edit].
3. Enter the e-mail address (up to 320 one-byte characters) on the on-screen keyboard, and touch [OK].
[I]4. Touch [Set Schedule].
[I]5. Select ON/OFF for each schedule.
6.58.3 Model Name
(1) Use
To set the device name for identifying the copier when reporting the total counter.
SETTINGS)
[I]I-115
(2) Procedure
1. Touch [Model Name].
2. Enter the model name (up to 20 one-byte characters) on the on-screen keyboard, and touch [OK].
6.58.4 Send Now
[B](1) Use
To transfer the current total counter value to the set address
Kidaver
04-19-2016, 08:08 PM
I had this very question myself and called tech support....took them a few days but this was the info they send me
Please go into admin mode in Pagescope, then select Network, then select IPP Setting.
Now, enter a name under Printer Location.
allan
04-19-2016, 09:15 PM
I will check that thanks. :D
