View Full Version : CQ Konica Minolta 6501 Shadow Gradient
Arcadian
04-20-2016, 05:16 AM
I have two color machine 6501 Konica Minolta.
okay Both machine have the same setup, both are networked and works fine printing but when i print Text with shadows or outline gradient You can see in the picture
Top one is the good copy but when i run the same file on the other machine you will see the gradient looks different, is there a setting i am missing somewhere???
32619
You can see the top one is good but the bottom look like it has more gradient to it like its not fitting properly or shading is off. im not sure what you call it.
But just doesnt look right..
Anyone have an idea???
Thanks in Advance!
DigiMan
04-20-2016, 07:23 AM
PM Drum Dev etc,all within life span?
Mick01
04-20-2016, 11:58 PM
Hi,
Usually these issues are caused by a number of items.
1) Printer Gamma Sensor adjustment needs to be re-done. Clean the Gamma sensor and conduct the adjustment. This will set the internal gamma curve for the engine.
2) After the above has been done, cunduct Printer Gamma Offsett Adjustment. This will balance the "highlight areas" (light gradations).
3) After the above conduct Gamma Automatic adjustment.
4) Calibrate the Controller.
Hope this helps
Arcadian
04-21-2016, 06:28 AM
Awesome i will try these suggestion and report back, Next week Im changing all drums and developer on the machines
but i think the gamma suggestion will help.
thanks again guys..
Arcadian
