View Full Version : c-5603 on 554e
splblazer91
04-21-2016, 09:04 PM
Anyone have a fix for this?
We have replaced the FSB, Expansion Board and Print Head unit. Still no luck.
mphile
05-24-2016, 03:56 PM
Good day you all,
I have got the same problem and mine is a bit different, I have gone to replace Cyan Dev Unit and BOOOOM!! when I turn on the machine it comes with error code C5603. Now machine wont respond even if you re-install the old unit. Please note the machine was not asking for dev unit to be replaced, I had to replace because of copy quality. Any help will be appreciated.
splblazer91
05-24-2016, 04:13 PM
Mine ended up being the PRCB.
javier4065
07-07-2017, 09:25 PM
Hello friend where is the front board and the print control board because I have de same problem c5603 First display says c2563 thanks in advance
Synthohol
07-07-2017, 09:46 PM
FSB is behind the plate (3 screws) that the DV units hide behind.
also...
3.10.12 C5603
(1) Contents
Trouble type
Expansion control board communication error
Trouble code
C5603
Rank
C
Detection timing
Communication error is detected in expansion control board.
Trouble isolation
Relevant electrical parts
• Expansion control board (EXCB)
• Front side board (FRB)
• PH unit
• Printer control board (PRCB)
(2) Procedure
Step
Action
Control signal
Location of electrical components
1
Reboot the machine.
2
Check the connector between EXCB-PRCB for proper
connection and correct as necessary.
3
Check the connector between FRB CN5-PH unit for
proper connection and correct as necessary.
4
Check the connector between FRB CN2-PRCB CN8
for proper connection and correct as necessary.
5
Replace EXCB
6
Replace FRB
7
Replace PH unit
8
Replace PRCB
http://www.copytechnet.com/forums/attachments/konica-minolta/37085d1499460979-c-5603-554e-excb-jpg http://www.copytechnet.com/forums/attachments/konica-minolta/37086d1499461144-c-5603-554e-fsb-jpg
3708537086
javier4065
07-10-2017, 01:32 AM
also...there is not way to reset this code maybe a service program thanksh
3.10.12 C5603
(1) Contents
Trouble type
Trouble code
C5603
Rank
C
Detection timing
Trouble isolation
• PH unit
(2) Procedure
Step
Action
Control signal
1
Reboot the machine.
2
3
4
5
Replace EXCB
6
Replace FRB
7
Replace PH unit
8
Replace PRCB
3708537086there is not way to reset this code maybe a service program because tje first problem was changing developer thanks
Synthohol
07-10-2017, 05:34 AM
turn it off with the main switch inside the door, hold down panel reset while turning it back on, close the door and hold the reset until you see a black dot in the upper right. you can let go.
next in a few will be a box that says trouble reset. touch it, it should say OK.
power off and wait 10 full seconds and power up.
let us know.
