View Full Version : Di251 Customer forgot his password for web access.
mheon
06-26-2008, 10:09 PM
How can I reset the web access password for a Di 251 print controller?
Any help would be appreciated.
Mark
Hansoon
06-27-2008, 12:11 AM
Never had to do it but I could imagine that resetting the NIC with the OP2-FACT jumper would do that. Switch machine off and put the jumper momentarily to the other side, switch machine on and wait until the leds start alternating flashing or at least 3 minutes. Switch machine off, put jumper back to its original position and switch the machine on again. Now you might be able to use the default password SYSADM again. The manual also mentions resetting of the controller NVRAM to the factory settings by putting the dipswitches 0,1,2 to off and 3 to on. Since I never had to do this and don't know what will happen exactly, I would try first the more simple NIC resetting and only if this doesn't work the controller NVRAM resetting. Hans
