View Full Version : Miscellaneous Konica Minolta C280 Printer Driver on MAC
mearmi
05-10-2016, 06:52 AM
Konica Minolta C280 Printer Driver on MAC doesn't show duplex/double sided option.
Please advise.
EarthKmTech
05-10-2016, 01:24 PM
keep looking
it's one of the many finishing options drop down lists.
(assuming you are using the correct driver)
copier addict
05-10-2016, 01:56 PM
You may have to go into CUPS to enable duplexing.
Synthohol
05-10-2016, 05:39 PM
Correct, however duplex is the default on pc or mac. Its just trying to be "green"
Long story short, go to terminal and type cupsctl webinterface=yes hit enter. Close window.
Open browser and type localhost:631/printers.
Select the konica and the dropdown that says administration drop down and select default options.
Under layout you will see 2 sided printing as the default. Change to 1 sided and save. Sometimes thwre is a ok button at the bottom other times you just hit enter.
Most of the time a password is reqd of the user.
As far as when sending a print there is a dropdown for layout or finishing that has the simplex/duplex option.
