View Full Version : buzhub c364e temperature control
dc-master
05-10-2016, 11:27 AM
dear friends,
I have a bizhub c364e and I tried to print on some color transfer papers (proworld 301 and 530),
but while printing the lighter one (301) the paper got stuck to one of the roller which I think was because of too much heat.
Is there a place in the settings in which I can adjust the temperature of printing?
thanks in advance
allan
05-10-2016, 01:26 PM
Yes you can in service mode.
Its under "machine"
What paper type did you use?
dc-master
05-10-2016, 01:57 PM
Its under "machine"
thanks for your response, I used ProWorld Elite+ Paper (item #530).
allan
05-10-2016, 03:12 PM
Hehe. Sorry i mean the paper type setting on the machine?
blackcat4866
05-11-2016, 02:29 AM
Like allan suggests, it would be a lot easier to select a media type with a warmer or cooler fuser temperature, depending on what you want.
Personally I don't recommend running that sort of stuff through a copier. You may find yourself needing a fuser much sooner than the yield. =^..^=
rrrohan
05-12-2016, 12:51 AM
454 has transparency paper type option. I'd like to assume you already used that option
Sent from my SM-G900I using Tapatalk
