View Full Version : Dead Machine Ic 601 controller is not connecting to the C6000L. Any one had problem like this?
Shape_Shifter
05-10-2016, 12:41 PM
Hi,
I have problem with connecting controller ic 601 to bh C6000L.
When i turn on the rip fans are constantly working without change of speed and on lower left corner of the display i have message that " controller is not connected" also in the top side of the display dos't show me HDD tab.
If any one know please help me
digfm
05-10-2016, 11:05 PM
Maybe the Power Supply in the controller is faulty.
Th eonky think is to try another PSU, because is similar like a Pc but
has 2 different connectors.
Synthohol
05-11-2016, 10:18 PM
the system software could be corrupt, can you web into it?
also try reseating the interface cable a few times on both ends and reboot both.
mik77
06-17-2020, 10:39 PM
Hi
Does anyone have a resolution to this problem?
Synthohol
06-18-2020, 12:59 AM
4 years later? ;)
the 601 is garbage, we swapped all those to Fierys and returned them for credit.
that machine and controller are discontinued now.
good luck man, im sorry you have to still deal with one!
mik77
06-18-2020, 07:40 AM
Thanks for the advice.
Can anyone help me out?
digfm
06-18-2020, 08:26 AM
Hi, first is how describes in previous message is to inspect the power supply it can be faulty
After this if You know that the PSU is ok, try to reinstall the
SYS software through the download in service mode (You need to make an USB with firmware for the IC601)
If You cannot load software after this try to look the HDD’s. The IC601 has 1 ssd and others are normal HDD. Maybe one of HDD’s have bad sectors or are died. The HDD’s can be checked through a normal PC
