View Full Version : bizhub c300 color copies are moved
javier4065
05-11-2016, 02:03 PM
hello, when I make black copies, they are ok but colors copies are moved . what can I do to solve it.thanks in advance.
Synthohol
05-11-2016, 05:06 PM
Hello, try cleaning the 2 sensors under the front of the transfer belt then run colir registration and see if it improves.
You will have to open the shutter that protects them to get access.
5 minute job really.
javier4065
05-12-2016, 12:26 PM
thanks, I will try it, where is color registration adjustment , in utility or service mode?
Synthohol
05-12-2016, 12:33 PM
service
DrMark504
05-12-2016, 03:42 PM
moved how? color reistration shiting each color equally from the black?
javier4065
05-12-2016, 07:44 PM
thanks, I will try it, where is color registration adjustment , in utility or service mode? where are the sensors that I should clean?
I dont see them?
javier4065
05-13-2016, 07:16 PM
I send the imagen of my problem. You can see on the pattern that black squares are not the same level that color squares.people say me that it I should change the transfer unit. but I see it good .
javier4065
05-13-2016, 07:24 PM
i send the patter the lines are bad. maybe you can help me, thanks.
javier4065
05-17-2016, 01:28 PM
thanks for your help. I cleaned ,laser unit, two sensors under the transfer unit end the transfer unit, and the color copies are ok now.
