DocSol
05-11-2016, 07:50 PM
Gents
We have one of these which randomly stops fusing mid job.
Sheets come out cold & you can rub the print off easily, but no error codes show & the machine runs for ages like this. If you stop the job, pull the ADU out & close it again the machine runs & fuses correctly. Huge clumps of melted toner come out stuck to the rear of the sheets until the lower roller is clean.
A fully refurbished complete fuser unit has been fitted, upper roller, lower roller, aux roller, all lamps, all temp sensors & web. Pressure is fine & good connection is made on both connectors on the engine.
Lamps all checked for operation.
Temp has been increased to maximum & the low temp environment fuser control switched on.
Still doing it. Need to start looking at board's now I think but thought I'd ask here 1st as we have no test board's so it's going to be expensive.
Thanks in advance
Sent from my SM-T560 using Tapatalk
Thanks in advance
