View Full Version : Fail Reset in Minolta C 451
Andre Luis dos Santos
05-16-2016, 07:38 PM
Hello , I need a big help of you . I have a C451 Minolta and she is asking the exchange of Fusion .The merger can not be reset in the technical mode. I've tried to put a fuse 80 mA . What can I do to reset the fusion drive ?
allan
05-16-2016, 07:54 PM
U need a 63mA slow blow fuse. Its all about the time it takes to blow the fuse.
Did the 80mA fuse blow out?
Synthohol
05-17-2016, 11:08 AM
allan is correct, a .063A (1/16 amp) pico fuse is what is needed. PICOŽ Fuses - Littelfuse (http://www.littelfuse.com/industries/telecom/fuses/pico-fuses.aspx)
years ago we used an analog corona wire about an inch long and that used to work 3 outta 5 times.
05-18-2016, 01:46 PM
I tried to reset the corona wire , without success. The fuse of 0.63 A not found in the city to buy. Any other suggestions? Thanks to those who tried to help .
Tech Helpdesk
05-18-2016, 01:53 PM
32929
Check ICP2 on the Printer Control Board it may be blown. If you still have drum refurb kits for the DI250 or DI2510 they have pico fuses in the box, use one of those
Synthohol
05-18-2016, 04:20 PM
Not to sound harsh but you can always just replace the fuser with a new one. If the customer has a service contract they have been paying for one along the way.
If you cannot get the correct fuse you dont have many options.
Also when using a corona wire you must use one from an old analog copier. The corinas for digital machines are much tougher and will not "pop"
If there is an oil roller in the fuser its likely dried out and will only cause a call-back later when the rollers start to collect toner.
05-18-2016, 05:55 PM
I found a fuse 0.3 The right also ?
Synthohol
05-18-2016, 06:33 PM
No. .063 is correct or 1\16th amp
.30 is almost 5 times as resistant.
allan
05-18-2016, 07:07 PM
The ICP on the DR311 drum chip and the TN512 toner chip should be the right spec fuse to use.
copier tech
05-18-2016, 07:55 PM
No need to bother resetting the fuser, transfer life or image units, just turn off the warning in CE mode. (Firmware update maybe required depending on version)
Synthohol
05-18-2016, 10:33 PM
I agree however once it's calling for a consumable it won't work. You have to turn off notifications before EOL. Then it works.
05-20-2016, 07:23 PM
I found the fuse 1/16 on the Internet , bought and am hoping to get . Mando news of the result.
Synthohol
05-21-2016, 02:34 PM
good luck Andre!
05-24-2016, 01:34 PM
not sure gave the reset with fusitor 1/16 , what should I do now ??not sure gave the reset with fusitor 1/16 , what should I do now ??not sure gave the reset with fusitor 1/16 , what should I do now ??
05-30-2016, 01:54 PM
Whats EOL Function ?
Synthohol
05-30-2016, 02:31 PM
End Of Life
allan
05-30-2016, 05:00 PM
Andre.
Is the fuse blown after u try to reset it?
06-09-2016, 12:41 PM
Andre.
I managed to solve the problem , after trying everything , exchange resistor equal to the original , exchange fuser without success.I only changed a small board behind the machine.Serial Number: A00J H00C 00 PCB Name : Assembly EEAfter the exchange , the resetou counter, and the problem was solved
