View Full Version : Firmware for a Bizhub C452
Arteminium
05-19-2016, 08:31 AM
Is there anywhere I can find the firmware for a bizhub c452.
I've already tried Konica CSES, but couldn't spot it.
Any help would be appreciated.
kingarthur
05-20-2016, 03:53 PM
it's on infohub, search SAL after you've selected the product, when you do install, DON'T install scanner FW, I had one turn into a brick, something to do with the tsunami in Japan & they had to source different chips, so the FW killed the m/c
docdot69
05-20-2016, 07:38 PM
that's right, some of machines, after the tsunami in Japan had scanners from other manufacturer, so be carefull with updating scanner f/w. On the f/w upgrade screen simply deny updating scanner f/w, upgrade all the rest. Same things with bh 223.
All firmware and documentation on www.infohub.konicaminolta.eu section "archive" if you have permition to that hub ofcourse.
