View Full Version : Bizhub Pro 951 ORU-M reset
Keychain
05-20-2016, 04:09 PM
Anyone know how to reset or disable the "ORU-M" red warning on a 951?
soft switch 15 is already set to 0.
antone
05-21-2016, 11:56 PM
I like to know also...every time I do a pm..drum DV..never resets
Sent from my SM-N920V using Tapatalk
Synthohol
05-22-2016, 01:21 PM
are you doing the mandatory adjustments upon replacement? thats what resets the counters.
do you need the manual?
sometimes after the correct procedure you have to power off the machine briefly and turn back on and the messages will be gone.
you have to do the drum peculiarity adjustments or it will never run right.
antone
05-22-2016, 06:08 PM
I do all the adjustments. DRUM Peck ect....I will try turning power off
tech51
05-23-2016, 07:24 PM
On later firmware, a new button is available in drum peculiarity called (something like) drum package adjustment. After a pm you press it and it asks if you've changed dr & dv etc. On answering yes, it resets the counters and does all the adjustments for you.
antone
05-23-2016, 10:15 PM
Do you what level firmware?
Synthohol
05-23-2016, 11:08 PM
image v50 print v41 are current
splblazer91
05-31-2016, 03:40 AM
so still no answer to the original question?
Keychain
11-07-2016, 09:35 PM
Bumping.
Still no help
Synthohol
11-07-2016, 11:41 PM
it does not indicate that the 951 was supposed to use ORU?
"ORU-M Counter Rewrite (1250/1250P/1052. only)"
do you have the service manual?
says nothing about the 951 but the directions are there for the other models.
