View Full Version : Error Code C7000P - Please Set Replenish Toner Unit Correctly
riddler24
05-20-2016, 06:43 PM
Hey everyone!
Model is C7000P
I'm stumped....our machine started throwing the message "Please Set Replenish Toner Unit Correctly" but despite our efforts we can't figure out how to fix it. We've tried everything we can think of!
Thanks in advanced!!!!!
tech51
05-20-2016, 09:07 PM
The toner replenish unit swings out for servicing etc.
It has two retaining screws.
If you open the front door you will see one about halfway up the unit and one that has a long shaft on it at the top.
If the top one comes loose, the switch that tells the machine the unit is in doesn't get pressed and gives this message.
Check they are both tight.
riddler24
05-20-2016, 09:57 PM
THANK YOU SO MUCH!!!
MR01
07-04-2023, 11:41 AM
Hello friends,
I have a problem with one Konica Minolta C1100: it appears “Please Set Replenish Toner Unit Correctly” but don’t have idea what to do. Please can someone help me?
Thank you
https://www.copytechnet.com/forums/blob:https://www.copytechnet.com/faa51761-9bee-45c3-badd-bb21fbefeb3e
L0rdC
07-06-2023, 05:58 PM
Hello friends,
Thank you
read the second message :rolleyes:
