View Full Version : C6000L fuser roller cleaning
kandod
05-21-2016, 04:26 PM
When replacing fuser belt, the two rollers inside are covered with some sticky material, it is probably the special KM grease. So the question is should I clean them before putting the new one, and what cleaning material should I use. Thank you!
CopierCare
05-21-2016, 06:04 PM
I clean the rolls up each time I replace the fuser belt. I use alcohol. May dry the rolls a little but cuts through the grease and I haven't had one dry out.
Synthohol
05-21-2016, 07:36 PM
ive used varn blanket wash for years and never had an issue. with the exception of white cuticles on my fingers, i clean those rollers dry every belt change.
kandod
05-25-2016, 10:15 AM
Thank you for the replies, i have replaced the belt and almost immediately the inner edge pressed towards the regulating sleeve
33008
Any ideas? Thank you?
DigiMan
05-25-2016, 11:12 AM
You sure you're using the right belt?
Is the belt straight side to side?Even the slightest deviation can cause it to flip.
Also does this thing have a lot number and if so is it placed in the right direction?
kandod
05-25-2016, 11:55 AM
Found the problem, the fuser roller /2 metal bearing was set up improperly with the limiter from the outside, very stupid mistake, thank you for the help!
