Non E series.
Few months back there was bad skew in tray one only even with plain letter. They do however run thick paper over spec in that tray alot.
I replaced all rollers and one ways. That fix it last time for a few months
Same skew again. I went ahead and replaced rollers and one ways. All three rollers used were A00J563600. That is all I have. I cleaned the registration roller well. I test again with lattice pattern but skew is still there.
I then look at loop setting. Tray 1 is at 5 and tray 2 at 0. I set tray 1 to zero and then it prints perfect. Then curiosity had me set back to 5 and it was still ok so makes me think it didn't help. It was working so I let it go. Paper path looks good from visual inspection. Tray 2 is perfect.
I got a call back and decided to order a paper feed assy but it is backordered for a week. Told customer that they could use tray 2 but they say image is shifted over too much in that tray. They need to print on 80 lb paper but bypass is skewing a little with this paper.
Account is 1 hour 45 min away. Gonna half to make two more trips unless I can fix without entire paper feed assy. Any ideas. I at least gonna half to go out there to fix the tray 2 centering.
Sent from my XT1254 using Tapatalk
