View Full Version : konica 1312 f34 error
simple_john
06-30-2008, 02:47 PM
hi we have an older konica 1312 copier. it has 93,900 page count and shows an F34 error when it turns on.
does anyone have any idea as to that code? its out of service and i dont have a repair manual.
Any suggestions would be appreciated. Thanks
sj
ni311
06-30-2008, 04:22 PM
F34
Fusing high temperature abnormality
The fusing temperature exceeds the specified temperature. (Detection temperature = 225°C)
simple_john
06-30-2008, 04:35 PM
thanks, is there anything i can do to prevent this from coming up? replace the fuser? or is there a reset anywhere? it gives me that error the second its powered on.
thanks
Don't try to reset the code before the fuser unit is being checked and fixed. The Job must be carried out by a qualified tech.
copycommerce
07-01-2008, 10:47 AM
There are one or two thermistors at the fuser.It depends of the model.I can say that probably one of the thermistors is dirty with toner.U need to clean it with AMB.If the thermistor type is with two plates u need to separate 'em.Then reset the code and all should be fine.Some of the old analog machines are one of the strongest and very easy to service.
simple_john
07-01-2008, 01:39 PM
Thanks for the info, im trying to find the manual to see if it will explain how to get at the fuser and how to reset the error code..
thanks for the help
sj
